- Plano, Texas, USA
Windshield Washer Fluid Low Level Dash Indicator
The wire you saw should be for washer pump (#5), not for fluid level sensor (#3).I just went out to the garage to see if our CX-5 has an indicator. I didn't see anything on the dash when I turned the ignition on but in looking under the hood there appears to be a wire connected to the washer reservoir. It's on the front of the tank, between the tank and the radiator. I could be wrong though.
