- 2003 Mazdaspeed Protege 1660, 2004 Winning Blue RX8, 2005 Mazda6
Civic gear oil is the same way. Like water.
Sent from my HTC 10 using Tapatalk
Up until Honda actually branded their own "MTF", the fluid recommended was 10w30 or 10w40 engine oil. With that being said, I was reading a fluid comparison chart and the MTF is basically the same weight as a 10w40 engine oil. I believe the only real difference is additives.
I put Syncromesh (Pennzoil) in the transmission before last and I've used it for a long time, different applications, and never remember it being as thin as the GM. I started using it in my Integra, then Civic when I developed the notorious Honda third gear syncro grind. It was great, made it almost non-existent. From that point on, I've always recommended it assuming it's comparable to what would otherwise be used.
