- RDX Aspec Adv.
So, I'm going on a hiking trip with a friend and she asks "What's wrong with your car?!". Apparently, she heard a noise. It was present under LIGHT throttle at highway speeds, and sounds like a nut/washer/bolt inside a metal pipe being "swirled around" forcefully like a coin rolling down a wishing-well funnel. At least, that's how she described it. I have hearing loss in some frequencies, so I likely cannot hear 100% of what she does, but I DID hear somewhat what she meant. I had always written it off as maybe the way gas swirls through the cats or the folded header (My 370Z had a "rasp" exactly from this, and it was well known), or maybe the sup[er high pressure DI system, or the "pusher" fuel pump, or whatever. long story short, I've had a lot of vehicles with a lot of their own "personality" type noises. However, she seemed/seems genuinely concerned, and since she finds it odd, I'm now curious if someone knows what it is, too. The BRZ has "crickets" because of the fuel-pump, the 370Z has a "rasp", the LS-series engines have "popping" from the injectors. So what's with this?
