FYI: Units on market to service units without external AT lines.
http://www.nationaltoolwarehouse.co...map=ROB92500&gclid=CPjZw6L9sc0CFYhffgodS_QMIA
" Our unique approach to exchanging fluid through the transmission oil dipstick"
http://www.robinair.com/sites/default/files/526233_E.pdf
Dipstick Only Mode —Transfers used ATF and new ATF through the
transmission’s dipstick tube by running a hose directly into the transmission
fluid pan. This mode eliminates the need to remove the cooler lines.
Dipstick/Cooler Mode — Initially transfers used ATF and new ATF through
the transmission’s dipstick tube. Then with the engine running, new ATF is
pumped into the transmission through the dipstick tube, while the used ATF is
evacuated through the cooler lines. This mode provides the quickest transfer of
used and new ATF.
Cooler Only Mode — Transfers used ATF and new ATF through the oil cooler
lines. Use this mode if the transmission does not have a dipstick.
Manual/Top-Off Mode — Manually adds or removes fluid to or from the
transmission pan. Use this mode if it is necessary to remove the transmission
pan, or to add fluid when using another mode.
