You come on this forum making radical hp claims selling your $600 "tune" but offer no in depth details on how you achieve that or the tradeoffs, while acting like a prima donna and having little knowledge of the tools you are using. I wouldn't let you touch my CX-5 with a ten foot pole.
Sure.
I have posted multiple dyno sheets. Many of which validate my claims about how much HP is possible to achieve with a tune. Every single dyno sheet being run, controlled, and completed by third parties.
Have posted in depth information on the controls of the ECU, logic, and how it runs. no indepth detail? I gave several in depth details.
Little knowledge of the tools I am using. OK.
I actually explained in great detail how it is done, what is changed, and the tradeoffs in the other thread that had most of the posts deleted. Surely you will use that as your defense because I can't bring deleted posts back.
You on the other hand make wild assumptions about the control system, knock retard system, benefits of running 91 octane, etc. With absolutely NO proof whatsoever, and use the excuse "I wrote firmware" as your reasoning for thinking you understand. You also compare them to other control systems and think they all work alike (about as wrong as anyone can possibly be)
You claim using IDA to disassemble the ECU is a waste of time, Several companies use this exact strategy and are quite successful.
You claim every company I listed does not disassemble these ECUs to understand them. Proven wrong with a 10 second google search.
You claim that it is impossible to learn the structure and logic of the ECU with IDA and low level instructions. Proven wrong with a 10 second google search
You, without any form of proof whatsoever, make claims to how the ignition strategy, knock control strategy, and other control parts based on... nothing.
You then compare the skyactiv ECU to an old Ford unit (26 years old) and fail to understand why the skyactiv ECU doesn't work the same way.
You claim the knock sensor indirectly adjusts the ignition timing for octane ratings.. how? Any evidence whatsoever?
You do not even know what processor these control systems use
You do not even know the actual size of the BIN file (until I told you).
You do not even know the various temperature controls in the ECU
You do not even know the fuel strategy
You do not even know the thermal efficiency strategy
You do not even know the cold start ignition strategy and why it used
You do not even understand the ignition timing system or how it functions AT ALL.
You do not even know the variable cam timing strategy, how and when it is used, under what conditions and ideal angles.
You do not even know how the ECU uses the ideal variable cam degrees to calculate fuel
You do not even know anything about the Skyactiv Ion system.
You do not even know the Torque control strategy
You do not even know how the ECU limits XXX YYY ZZZ for the torque control strategy (feel free to tell us what XXX YYY ZZZ is if you do know, but I already know you do not )
You do not even know about the oil temperature system
You do not even know about the EGT control system
You do not even ...... I can keep going.
You sir, are a troll. I literally just listed out several in depth control systems inside this ECU yet I am the clueless one.
Proof you are a troll: my tune for the CX5 is $500, not 600. But I understand why you did that
You casually skipped over the fact a 3rd party on this forum also concluded you were false in your statement and you made some BS excuse about the companies giving the information away, but not long before that post you were saying how the source code and information is worth millions of dollars and held under tight security and nobody could gain access to it. But after being proven false, these companies now give it away, only it a crude attempt to make it look like using IDA to disassemble these ECUs is the wrong way of doing it. However, you were already proven incorrect in that very statement.
"The first goal the group set for itself was to document the ECU by disassembling it byte by byte. " -lol
Thanks. This is my final reply to you. Everyone here knows you are a troll.
Oh and to counter your argument that I have no proof, how do I know all of these control systems exist?
