SayNoToPistons
Wheels, not rims...
- CX-5 GT AWD w/ Tech, RX-8 GT 6spd w/ 'goodies'
Out of boredom and curiosity, I tried adjusting the driver side projector about one counter clockwise turn HIGHER as many have suggested. Results?
ABSOLUTELY horrible alignment. One turn will not only result in completely mismatched left and right projector cutoff beam alignment, it also blinded on coming drivers and ahead drivers. When traveling about 2-3 car lengths behind a midsize sedan, the driver side projector is noticeably higher than the sedan's side mirror. It gets worse the further back you are, as the beam is angled with a positive slope with the new settings (which should NEVER be the case). Of course, it blinded on coming drivers as well.
As I mentioned before, the cut off alignment was completely off from the passenger side projector's cut off beam. Now this part bothered me the most. With original settings, the beam was extremely wide and even, with flawless light distribution. With the misaligned projectors, it totally threw everything off and reminded me of poor lighting from those HID kits in halogen housings. There were hot and dead spots in lighting through out the two projector's beam patterns.
The cut off line shouldn't be completely straight from left to right. Each projector will have an obvious step on their cut off beams, a total of two, but there should be a total of ONLY ONE STEP when the projectors are aligned. That means there should be one straight line in the beam starting from the left, and as you go further to the right near the center (for LHD owners), there will be one step up about a few inches in height, and another straight line follows to the right end of the beam.
I spent one minute MISALIGNING my headlights for curiosity sake, spent a few days being annoyed at the horrid beam pattern also annoying others on the road, and about 30 minutes aligning my projectors back to perfect factory beam pattern. Definitely not worth it.
If you're going to adjust your damn headlights, adjust BOTH accordingly. Though chances are if you adjust them higher than factory spec, you will be blinding damn near everyone with at least your passenger projector.
Just because there have been too much misinformation posted in this thread already.
But, hey. Do whatever you want. Your car right? As long as you get what you want. Who cares of other drivers think you're the asshole blinding the s*** out of everyone. Much like those assholes with their highbeams on at all times or cheap misaligned HID kits in their halogen low beam housings.
