Quiksilverly
Find Sexy Girls in your city for night
- Usa
I have the MS2 almost completely built but am debating whether to run the fs-ze idle with the FS-DE ecu. Will it work well enough at idle to do the trick or do I need to wire it into the MS2 and get a GM step motor style IAC? I'm specifically asking can the FS-DE ecu run the IAC function for the FS-ZE efficiently? The reason I ask this is that the FS-DE ECU is not adequate enough to get proper result out of the FS-ZE in regards to fuel or spark from what I hear....does this mean it will not be able to adjust the idle on start up in cold, or with A/C on????
