I didn't give up vinyl because replacing vintage vinyl, mastered when the session tapes were new, with any digital copy made when the tapes were 40+ years old is a huge step backwards in quality. It's not that digital doesn't sound good, its that you can't get the music off those tapes that time has removed. You get a dullness in the highs and upper mids combined with hiss that comes up when the mastering engineer tries to EQ in what time forgot. If you never listen to music recorded earlier than the 80's vinyl is a waste of time. Yes, Ortofon is still in business.My 2015 Blose systems sucks. Worst I ever heard in a car audio system. I should have listened to it closer. I didn't think I'd detest it this much.
Actually, I'm looking for midrange, especially upper mids.
Is Ortofon still in business? I gave up vinyl when I found 24/192 DVD audio. I still have my old Thorens with Decca London arm and A-T MC cartridge, want it?![]()
If the CX-5 system is the worst car audio you ever heard, you must have been driving some pretty expensive cars or all aftermarket systems. As far as stock systems go, mine is in the upper third. Everyone that has ridden in my car thinks the Bose system sounds pretty good. Surely there is room for different tastes but "worst ever" makes me think there is something wrong with it or you are using lousy sources. The FM tuner sounds bad, XM is acceptable but just so. USB and CD sound good. I have had Subaru's, an Audi, a VW, a Jeep, a couple of Mitsubishis, Fords, and a BMW that were far worse, most of which I either upgraded speakers or threw out the whole system.
If you are saying that the system is lacking upper midrange, you are wrong. If Bose knows anything, they know how to EQ a system. If you are saying you don't like the way the upper midrange sounds, then you are probably playing it way louder than I do. The system has its limits. Played at reasonable volume levels (up to 60 or 70 %) it sounds good. When you really push it, things fall apart starting with upper midrange glare. This just happens to be at volume levels I rarely use. If I was a heavy metal fan, I would probably not like it.
If you own a Desmoquattro, you have plenty of discretionary funds. Replace the awful Bose system with something better.
