- 2003 Mazda Protege5
Hi all,
I'm new here and this is my first post. I've been lurking for a while now...I love the site and I appreciate all of the knowledge and help I've gained from this site already!
That being said, I'm looking for a wheel hub assembly for the FRONT of my 2003 P5 which has NO ABS. I haven't had any luck finding one? I'm looking to replace both wheel bearings and hubs on the front end, hence my search for the wheel hub assembly.
Also, am I correct in thinking the wheel hub assembly will come with a new wheel bearing already pressed into the wheel hub? That's half the battle here and part of the reason why purchasing the whole assembly is so appealing. I already want to replace both the wheel hub/bearing on each side and I'm thinking I can do this with the wheel hub assembly and avoid having the bearings pressed altogether...is this correct? Or does the assembly kit simply come with the bearing separately included, thus needing to be pressed in before installation into the knuckle?
Any info on where to find the assembly and whether or not I need to have the bearings pressed once I receive the assembly would be much appreciated! The main problem I'm having is finding a wheel hub assembly for the FRONT with NO ABS.
Thanks in advance!
Thanks in advance!
