katapaltes
'03 P5, '17 Miata, stock AF
- Dallas, TX
- 2003 Protege5
So I think need to replace my valve cover gasket. (The bolts were so loose at 99,000 miles that I could spin them with my fingers and I lost about a quart of oil to leaks until I figured it out and tightened them.) I'm at 112,000 miles now and the leak is not too bad, but it is leaking a little. I called my local dealer and they want a reasonable $40 for the valve cover gasket itself, but between $6 and $9 *per grommet* for the 11 little round grommets (two different kinds of grommets; not sure if that includes the round metal pieces that I don't need to replace or even if "grommets" is the right word here). That's a total of $131 for the entire set.
O'Reilley has a Fel-Pro gasket set that *includes* the rubber part of the grommets for $35 and they're across the street from me. My question is, are the Fel-Pro gaskets/grommets any good? I've searched and searched and not found a definitive answer. Perhaps there's another gasket *set* I can buy that's more expensive and better than Fel-Pro, but not as much as the dealer's $131? Or do I even need to replace the grommets? I do think oil may be leaking from around them as well as the gasket itself. Then again, if the gasket is leaking, it could just be letting oil through to the valve cover bolts, and if the gasket was replaced, maybe any leak around the grommets would stop...
