Cranks, won't start
Replaced cam sensor and crank sensor. Still no spark and no fuel. Crank sensor was pretty chewed up. Timing gear looks OK although mechanic says it is the thinnest gear he's ever seen.
Does anyone know of any hidden fuses on this car? I know about the fuse box below the steering wheel and the fuse box under the hood drivers side. All these tested good, any others?
Replaced the computer and that fixed the problem but 60 days later the computer went out again. Any idea what would make this thing start blowing computers?
Turns out there is a drain tube from the sun roof down to the passenger side firewall. When this drain tube gets plugged with crud then the computer under the passenger side floorboard gets wet and dies. I hope my headaches will help someone elses
