CX5-SO
CX-5 SPOUSE
- 2013 CX-5 Touring AWD A-T
I have coming from Amazon
OEM Tools 22297 23mm Metric Socket (THIS IS A VERY SHALLOW SOCKET)
https://www.amazon.com (commissions earned)
OEM Tools 22298 24mm Metric Socket (THIS IS A VERY SHALLOW SOCKET)
Genuine Mazda Fluid (0000-77-80W9-QT) SAE 80W-90 Rear Differential Oil - 1 Quart
I have coming from arlingtonmazda.com
DRAIN PLUG WASHER (ISH9956-41-800)
http://parts.arlingtonmazda.com/products/DRAIN-PLUG-WASHER-%28ISH9956%252d41%252d800%29.html
Thanks go out for the member that gave the plug head sizes!
EDIT: 07-11-2016
MAZDA HAS CHANGED THE SPEC ON THESE FLUIDS FOR LATER YEAR MODELS. CHECK YOU OWN OWNER MANUAL FOR THE RECOMMENDED LUBE FOR YOUR CX-5.
EXAMPLE DIFF. BETWEEN 2013 AND 2016 YMs
EDIT: 07-11-2016
