ZealoustheEnder
Contributor
- 2003 MSP
MPP Eastwood finder finisherWhich group? That's something that would be worth having around
Sent from my HTC Desire 626s using Tapatalk
After you get the tune straightened out then you can install my air box and piping and save a tune for meView attachment 212031
She has a heart! I'm waiting on the battery charger and enjoying some tikka masala. I'll be starting her in a bit![]()
After you get the tune straightened out then you can install my air box and piping and save a tune for me ��
I'll just need a better than stock tune. Disco potato 10psi stock injectorsThat's easy enough. What injectors will you be running and how much boost are you shooting for?
I think the big mistake in my forged engine build was changing too much at once.The car is together, but it doesn't want to run. It fires right up but rather than settling into an idle it just dies. I managed to baby the throttle once last night and got it to run for about 10 minutes before it abruptly died. I figured the issue was fuel pressure (or a lack there of) as I've switch to an afpr, jay racing rail, and 440s. But while it was running last night I got the fuel pressure dialed in to a steady 40 psi. I had also changed around and deleted a lot of the vacuum system, but I've since put everything back to stock and I'm not having any luck. The MAF and MAP sensors are plugged in and were in fine working order when the other engine came out. The crank and cam position sensors came on the engine and are unknown quantities. Any thoughts?
Illa, did you rent, borrow, or buy the fender roller? I may have to roll my fenders to clear the sti BBS wheels I picked up. I have to refinish them before they'll go on the car, but clearance could be a problem.
Paint both of them to match.So I thought if the P5's could have one of these we could to. Hopefully there are enough people doing things to their MSP's to keep this going. Ill start.
I finally got tired of my ghetto looking dual gauge pod and spent the money on a full a-pillar (thanks ********** (first) ). I'm going to paint it whenever I can get hold of some of the Krylon #3551 Classic Gray and then put it in. Im pretty sure everybody will be able to tell which is the old and which is the new. I hope to have pics of it installed by the end of the week.
What year are the wheels from? The center hub bore needs to be opened up more to fit unless you run a large enough spacer.
Are they 5x114? Only the 05-07 were
I need a new shift boot. Got a link ? I can swing 6 bucks
