2016 CX5 Interior Light Bulb #s
littlebear
2017 Mazda CX5
Anyone have a list of what the CX5's interior dome light, hatch light, and map/visor bulb #'s are?
Looking to get LED's installed but need the bulb #'s to match it correctly.
My VLEDs order may be of some help (ignore the one exterior bulb) for my own 2016:
ORD'D SKU Description
1 194_4_HPF_W_5K 5K WHITE 4 LED HIGH POWER FLANK BULBS 194 168 158 160LM | 1 PAIR (License Plate bulbs)
5 3175_6_W_5K 5K WHITE 6 LED HIGH OUTPUT DOME LIGHT BULB 170LM 31MM 3175 DE3175 (Front/Rear Dome & Cargo bulbs)
2 VANITY_2_W_5K 5K WHITE HI POWER 3 CHIP 2 LED VANITY SUN VISOR LIGHT BULB (Visor--note, these are very bright, and may be too bright for some)
All bulb types for the 2016 are shown on page 9-7 (Specifications section) of the owners manual that came with your car(you can also download it in pdf at Mazda.com)
Not trying to be an A**hole, but thanks for nothing: interior light.webp
29mm festoon for the map/dome + trunk, 31mm fits also, known as DE3022/DE3175. License plate light is T10, also known as 168/194
I am not 100% sure if it is the same for 2016 though, as I have a 2014 model, assuming it will be the same..
Same for 2016.
Vanity lights are 29mm 6614F, 1 per side.
Same for 2016.
i got 2016 but with tec . the T10 are for license plate lights and reverse lights . 28mm or 29mm is in vanity . 31mm should be map lights and the trunk light . ebay search for T-10 / 28mm led or 29mm led or 31mm led and you will come up with a lot of leds . 5050 chip set is good . i use 5630 chip set when i can . 5630 has a little more of a blue tint but bright as heck .
I used a 3022 for the cargo light from vleds in my 2016 cx5, though the 3175 works as well, just a little looser, but not enough to fall out.
