hey guys,
just a quick update and improvement to our how-to procedure for transfer case oil change
http://www.mazdas247.com/forum/showthread.php?123847373-Changing-CX-9-transfer-case-gear-oil-%28photos%29
decided to swap my transfer case oil again after 7500 miles,I swear it's so easy I'm a pro at it now,
honestly, the hardest and most tedious part was pumping in the new fluid, takes almost like 10 minutes of manual pumping until I saw the new oil flow out of the drain hole.
basically if you can change your own engine oil, you can do this very easily.
actually the real reason was so I can play with my new $21 electric sunction extractor/transfer pump
http://www.ebay.com/itm/12V-5A-Oil-Diesel-Fuel-Fluid-Extractor-Electric-Transfer-Scavenge-Suction-Pump-/311107634544?hash=item486f75c570
the thing worked liked a champ!! much faster and cleaner than the sunction gun, with the sunction gun, I had to suction three times and dump three times, very messy, with the electric pump just had to hit the switch and let it run, see video
the amount of old oil sucked out was also about 30% more using the electric pump than the sunction gun,
it almost filled up the whole Poland Spring bottle, I was never able to get that much out both times using the sunction gun.
I hooked up the pump to my emergency jump starter and just ran it off that to power the pump as shown here:
also since this was the third time I did this, I had to add new VC-3 sealant:
