1574 has a miss that usually becomes a full on stumble when under load, today I again swapped both coil packs, boots, wires, and pulled the plugs, cleaned them and verified the gap was .028 even though I just installed and gapped them (NGK ZFR6F) a few days ago. Pulled the maf and cleaned it out thoroughly and started the car and it didn't change it at all, still stumbles just as bad. May try to load a different tune on the FTC and change the settings, not sure what else could be causing it to run so bad
Also ordered a set of 4 8mm spacers, going to put a pair on the front of 1345 so I will have 8mm spacers all around with the BBSs on that car and put a pair on the front of 1574 with the racingharts. I have a set of extended lug studs so I may put them on the front with some 10 or 15mm spacers and move the 8s to the rear.
