Mazda5 Information Display Totally Blank
Loves Mazda
Mazda 5
Hello everybody.
My Mazda 5 from 2007 has served me very well, but now I have a problem - that I hope someone have a solution to.
The Information Display is totally blank - not a single segment. The Clock which works separately in the left side of the display works fine. The Display light up fine - but when I turn on the headlight, the Display nearly loose all the light. This makes me think that the problem is connected to a fault, maybe in an electrical relay, that steel all the power to the Display. I dont think that the fault is in the Display it selves, as it doesnt show just a single segment. The AirCon, Radio and CD-player works normal - BUT after disconnecting the headwire to the Battery a few minutes, in the hope that a power-reset would solve the problem, the radio/CD doesnt work anymore. I gues that this is because it will take a passcode to install these functions again because of theft-security, but as I cant read the Display - I cant put in the code.
I have checked all fuses in the 2 fuseboxes, all relays for burned connections, disassemblet the Display to check all solders - but everything looks fine.
Does anyone have an idear
Best regards "Loves Mazda"
Open the center dash and look for loose connection? Broken solder joints on the display board?
Hey phunky.buddha
Thank you for your answer. I have allready checked for loose connections, and specially the solder connections on the Display in a microscope, but everything looks fine.
Do you think that the fault could be outside from the display, as it dont miss just some of the segments - but is totally blank, and nearly loose all the light/power when I switch the headlight on?
Best regards
Hello Mazda friends.
I have for some times tried to find a solution to solve the problem with my Information Display - which is totally blank. Not a single segment. The clock on the left side of the display is OK.
Im pretty sure that the display itself is OK - and the fault is to be found another place.
I have checked all fuses in the 2 fuseboxes, and checket all harness connections I could find (hours of work to get in behind all the shields).
After reading different forums - I think that the problem is one out of these two possibilities:
1. The system has to be reset . by a partical code (how to do it?)
2. A Relay to the A/C Controls has a bad connection to ground (I cant find the relay)
Can anybody help me here?
Very best regards
Peder
Hello tawrus80.
Sorry - I didnt see your responce before now.
My Mazda5 is from 2007.
Climate controls works fine. Stereo is now out of function - but its because at a time I disconnect from the battery, and thereafter the stereo went off - but before that the stereo works fine, even that the display was blank.
Forgive me my danish/english language.
Very best regards
Peder
