I've recently started working on a 2003 P5 I just bought. It had torn motor mounts all around, so I filled the front, pass, and driver for now, leaving the big rear mount job for a little later on. The mounts turned out awesome, and I noticed a big improvement in the car on the first drive. However, when I started it up and took it on a test drive, I noticed a new belt squeal that wasn't there when I drove the car last. I got home to find PS fluid all around the reservoir, foaming out of it, almost like it is way overfilled.
I feel like I can in point the squealing I'm hearing to the PS pump, possibly a bearing gone bad. Do you guys think the new motor mounts have anything to do with this (engine slightly crooked in the bay?) or is it just coincidence that I fixed the mounts and the PS pump went out at the same time?
I'm picking up a used pump at the dismantler this weekend, so hopefully that resolves the problem, but if anyone has any other opinions or solutions, I'm all ears!
