So it appears that the new 19s are the same as the old, but with a different paint treatment?I really wish you could see it better, but I love the OEM wheels on the new 2016 model. I like how it matches well with the new grill.
	all of the color "matched" moldings I've come across are off color enough to be noticed. Same with many of the fender flares.agreed, love the lights though. has anyone colormatched the mouldings yet? have seen it on white and matte black but it makes the car a bit bloated in those colors.
	saw this on the internets
I may be getting new wheels (which I will sell my old one) and I wanted some opinions on this. I currently run a +40 8.5" wheel I am looking at a +45 8.5" or 9" wheel as the new one. Should I expect two identical wheels with the same offset but different widths to stick out the same? E.g a same wheel, 8.5" +40 will stick out as much as 9" +40?
Ah ok. Makes sense because the same wheel in a larger size was offered in a lower offset.Negative. A wider wheel with the same offset WILL stick out further due to its larger width. Offset is measured from the centerpoint of the rim's width to where the wheel's vertical hub seat lies.
A 10" wide wheel with 40 offset, will definitely stick out more than an 8" wide wheel with 40 offset. By 1" on each side ;-)
Just curious ... why do you want to go to a +45 offset, which will effectively bring the wheels further under the guards? I thought your +40 offset on an 8.5" wheel looked perfect from the photos I've seen of your car.
Ok, so it seems like my current wheels, 8.5" (216mm)+ the offset of 40 give it a total distance from the hub of 256mm (my tires are 255 as well). So a 9" (229mm) wheel with 30 offset will be 257mm from the hub, or roughly equal visually to what I have now, except the tire would be slightly less bulged. Do you guys agree with this as far comparing distance? I am thinking mybe a 9.5" with 30 offset to give me a *very* slight poke (+ I want a wider wheel).
New wheels arrived, just need to fit tyres and put on car , will go and take pic as they are in my shed
Great having a Mazda Dealership guy as a mate , when clients buy new cars and upgrade the wheels to 22" he helps them offset the cost of te upgrade by finding a buyer for them , luckily I got in first before the mag wheel shop that snaps them up, sadly the oem 20" rubber not the right size for my CX-5.
Do you like the new Shadow Chrome 20" CX-9's ?
