Bikingpro5's build 2
Jay Racing fuel rail and custom length Jay Racing front endlinks
also received the CR3 lower brace
and the car before i tucked her away from the snow
rewrapped speed3 front seats- leather/suede with blue stitching, you can also see the CDM raised armrest and matching leather arm rest
[/QUOTE]
Do the ms3 seats bolt right in?
Also, don't part her out! You know she still makes you smile ;D
no they need either aftermarket sliders installed or you can weld the Protege5 mounts to the new rails.
might make me smile but art in my house hangs on the walls it does not take up parking spots in the garage :)
good to hear, i've been looking into these since my current battery is starting to go. Would you mind sharing the model number of the deka you went with?
Braille B106 - 6.6 lbs - 210 CCA's - Only recommend for warm weather racing/not recommending for a daily driver as per Braille.
Deka ETX9 - 6.3 lbs - 120 CCA's
Braille B129 - 9.5 lbs - 323 CCA's - In warm & cold weather only recommend for racing or as a motorcycle/chopper battery/not recommended for daily driven car.
Deka ETX12 - 9.4 lbs - 180 CCA's
Braille B14115 - 11.5 lbs - 360 CCA's - In warm & cold weather only recommend for racing or as a motorcycle/chopper battery/not recommended for daily
Deka ETX14 - 12 lbs - 200 CCA's
Braille B2015 - 15 lbs - 425 CCA's - Recommended as a daily driver battery in warm conditions (60-120 degrees), recommended as a race only battery for cold conditions (0-59 degrees).
Deka ETX15 - 14 lbs - 210 CCA's
Deka ETX20L - 15.5 lbs - 270 CCA's
^^^Not sure which Deka battery the Braille is modeled after in the 15 lbs range?!?
Braille B2317 & B2317R - 17 lbs - 475 CCA's - Recommended as a daily driver battery in both warm & cold conditions.
Deka ETX16 & ETX16L- 17 lbs - 275 CCA's
^^^Note, these batteries are meant to be used as a set to replace 2 batteries/supply 24V power ect.
Braille B2618 - 18 lbs - 472 CCA's - Recommended as a daily driver battery in both warm & cold conditions.
Deka ETX18L - 18 lbs - 330 CCA's
Braille B3121 - 21 lbs - 550 CCA's - Recommended as a daily driver battery in both warm & cold conditions.
Deka ETX30L - 21.7 lbs - 365 CCA's
Information pulled from the following:
Braille Battery USA
http://www.eastpenn-deka.com/assets/base/0278.pdf
my battery is the
Looks great JT, it has to be done at on point. So idk if you've mentioned it yet, but what car will you possibly be moving onto? Turbobrick? Lol
Right now I have no plans to mod any car. I have 2 reliable daily drivers and it's time to enjoy life a bit more than I have been.
