Show me your CX-5 wheels
I want to throw these on my liquid silver cx5 do u guys think they will fit?
measurements are:
View attachment 20907218x8.5 HRE style wheels
With tires of 245/40/18. The bolt pattern is 5x114.3 and the center caps are 68.5
If you mean "center bore" is 68.5 that is an odd size. gl in finding a ring for it, although ring is not a requirement. Check google.
You must of measured the wrong diameter. I have never heard of that diameter.
You have to remove the wheel and measure it from inside of the wheel.
Center caps?
Do you mean, hub diameter right? If yes, than that ring, will be very thin. They even make that thin? There is only 1.4mm difference between the two diameters.
Yea I meant hub diameter. That's what the guy quoted me on. I'm not gna get em bc the wheels won't fit but thanks everyone. I can't wait to post my cx5 once my h&r springs and new rims (once I find some) go on
I have picked up some Audi wheels and I will machine the bores out a bit. I will also use wobble nuts, with wobble locking nuts, they are on Ebay from a UK buyer($120/set).
posted wheels on here before but recently upgraded to 2013 oem ms3 wheels
Redline,
What size tires are you running?
I just picked up some 18" RX-8 wheels on Craigslist to put on my wife's CX-5 for the winter. still have to pick up some tires before winter but thinking about 225/60/18
Here are the wheels.
I have picked up these 20"-ers. Color will change.
Any ideas on how should I paint them?
Think outside of the box.
I'm thinking, black spokes with red "lip".
satin black with machined/polished lip and same for the small area on the wheel spokes
Thanks. They will be unique. They were $355(!), they are replicas, but still.
They will look even better, with the Corksport springs installed.
Will need to get wobble nuts and locking nut kit, which are not cheap($120).
Is this anyone's? I'm sprung and have found my inspiration.
