- 92 & 16 Meyatas
the wifes first comment to me after driving the cx5 all day yesterday, hiway, around town..."boy, that thing has some great pick up!" she had just drove the trib the day before so she noticed the power bump right away...
thanks! how do you like the taurus sho?
So finally I got around to installing a pair of LED headlight bulbs purchased off eBay a couple weeks ago. Here is the link to the specs: LINK
Haven't gotten around to taking pictures as it's past midnight but I moved over to these LEDs from Morimoto XB35 HID (4300K)from TRS. This quest started when another vendor was selling H11 LED headlight bulbs. I was curious to see if LEDs are truly ready for prime time headlight duty. The bulbs fit in fairly easily (especially after you have tried installing HID bulbs on a non-tech). Took all of maybe 15 minutes to remove my HID kit and put in these LEDs. Pictures are pending (charging the camera currently).
Observations so far:
- Light output against the wall is fairly close to HIDs
- Pattern and cutoff is similar to the HIDs
- It's nice to not have ballasts (or a relay) as everything is enclosed inside the heat sink behind the LED
- The bulb is hefty, all surfaces I can see (besides the emitters) are metal
- Documentation indicates the bulbs use Cree XM-L emitters (and they're bright)
- The light output is indicated on the packaging as 6000K but it is whiter than most 6000K HID kits I've seen
- Instant on to full brightness (whereas HIDs need to warm up)
Yet to determine:
- Throw distance of the headlight
- Longevity/reliability of the bulbs
- Glare
- Ability to light up reflective signs and road markers
So my quest for better LED lighting continues. Just purchased what appears to be something that VLEDS will be offering soon: http://www.vleds.com/h11-eti-3000lm.html
Once I get them in my hands, I will compare them with my existing set (considered gen 1 while these are considered gen 2) and the stock halogens when time allows.
are these the new ones? the site said they weren't available yet?I've just installed them and will give it a good run through when it gets dark enough...
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
[/td]
