Wow, didn't realize it was that much. What about this kit? Or is there another kit you would recommend? Also not sure about the options, harness, bulb, and ballast. Thoughts?The sockets are different for stock oem HID and halogen oem, aftermarket HID lights direct fit into halogen housing.
Stick with aftermarket unless you want to replace the headlights as well, they are only $860 each from the dealer.
I'm on my 2nd year with good aftermarket lights, no issue whats so ever, just don't buy a cheap set and confirm the are AC type.
also stock bulbs are $150 or so each, plus $250 for each balast, thats about $800 just in the hid lights, never mind new headlights at $1800 .
now you can see you only see talk about aftermarket.. good kit is about $60-$70, instead of $2600 for new oem.
Oh ya, and you will need new wiring harness for the oem, probably another $250 or so from the dealer. (i can't believe how expensive the oem parts are)
True... Unfortunately, I bought a car recently and wanted the Clear water blue, which was only offered in the 2013 and below. Used 2013 pickings are slim(i would have preferred new, if cwb was available)Well if you wanted OEM HID, GT should have been purchased![]()
The sunroof is an option on the Touring package, but unfortunately not available on the sport.90210, there are other factors to consider when making a purchase and sometimes there is a need to compromise. I wanted to have a sunroof, but those only come on the GT, all the GT I could find in my area were automatic, so I decided a manual transmission was more important for me than any other "toy" and got the Sport.
I call them convenience features. Honestly the sunroof stinks b/c it is way undersized. The 91 BRG is more toy and a fun and really good looking one at that90210, there are other factors to consider when making a purchase and sometimes there is a need to compromise. I wanted to have a sunroof, but those only come on the GT, all the GT I could find in my area were automatic, so I decided a manual transmission was more important for me than any other "toy" and got the Sport.
Do the +'12 come with manual leveling also?
Is there any way to make the fogs the drl instead of the low beams?No matter which kit you use do yourself a huge favor and get the appropriate relay harness from TRS to power it. This will save you heartache and pain down the road, trust me... Another thought just occured to me, you are gonna have to get rid of the DRLs before you go HID or the ballasts won't last a week.
Interesting, my 2012 uses high beam for DRL, not low, so I did not have this issue. I wonder why is yours different. Ask a dealer if they can re-program the computer to use high beam for DTRL.
I just direct connected to the normal stock wiring and have not had a single issue.
I prefer fogs as drl. I will check, honestly I am not sure what is used as drlIs there any way to make the fogs the drl instead of the low beams?
Sent from my LG G Pad 8.3
