Recent Calls Received or Dialed not Showing in Call List in Phone Menu
EddieFord33
2015 CX5
OK what am i doing wrong,, i do not get recent or dialed in the phone menu. The list are empty, yet my phone is connected?
Anyone have a clue?
In the paired config area in Bluetooth on your iPhone have you confirmed this option is turned on? Click on the question mark icon to get into the config.
Hi
thanks, is that on the iphone itself or the CX5 setup?
Oh, on my iphone it says Phone recents and it is check already?
It's on your iPhone... go into area where the CX-5 is showing up as paired on your iphone. There should be an question mark to the right that you can click for options. This may not be it but there is an option to turn on/off recent calls as being synced.
Thanks, I found it and it is already check as being on....CX5 BT seems kinda WONKY...to me, I am sure it worked before...now it does not for no reason...
There is a possible firmware update in the works but no ETA in US at this point.
I'd start by deleting the pairing on both sides and repair to see if that helps.
My recent phone calls show up only about 10% of the time. The screen is blank the other 90%. It has always been hit and miss, but mostly miss; it is something I've lived with.
