BadgerMazda
- 2013 Mazda5
Hey all, just looking for some pics or insight to what people are doing for a trailer hitch and corresponding bike rack for the rear hitch.
^ how much weight were you pulling? I just want to see if I can haul my motorcycle or an engine with ease. If I can it'll save me the hassle of having to get a truck.
IIRC, buried in one of these post there was a Canadian (?) member who towed two motorcycles to ride the "Tail of the dragon" in NC and said it was fine.^ how much weight were you pulling? I just want to see if I can haul my motorcycle or an engine with ease. If I can it'll save me the hassle of having to get a truck.
Anyone who installed a hitch have any problems with the heat shield or rear fascia touching the hitch and causing annoying vibrations and rattles. I installed a hitch on my Nissan Versa and still have not gotten all the rub points eliminated.
Depends on what hitch you are looking at. The Hidden Hitch and Draw Tight (same thing) does not go near the head shield. They are designed to mount to the tow hook on the exhaust side. If you know which Hitch you are after I’d recommend you search and look up the respective install guide to understand where/how it mounts. The Curt hitch for +’12 required cutting out the existing heat shield as the hitch has a build in heat shield. Curt did this to give you the most robust mounting points – on the car’s unibody frame. There are times (REALLLLLY bad NY roads) I hear something knocking in the rear but I’m not sure if this is the exhaust canister hitting the hitch or “something else” back there making a ruckus. We all know our rear suspension is awesome…Anyone who installed a hitch have any problems with the heat shield or rear fascia touching the hitch and causing annoying vibrations and rattles. I installed a hitch on my Nissan Versa and still have not gotten all the rub points eliminated.
