I installed Rear Moog Endlinks on my Protege5 and they're the best!
M2P503
2003 Mazda Protege5
I just installed Rear Moog Endlinks on my Protege 5 and they are the best! They have Grease fittings to and there just as beefy as the 2003 Ford Escape Endlinks if not better!
do these use 14mm nut?
Yes they do its actually a 14 mm nut on the inside that uses a wrench for it to hold it from spinning then the actual nut that goes on the bolt is a 15mm. I just use a Box wrench ratchet to snug it down and that works perfectly. Just make sure you tighten it to 40 pounds and your done! I hope that helped!
