This has been something I've been wanting to do for quite some time now, and have been debating whether I should or shouldn't. I decided I should.
Like most, I started bog stock, but before i get into that, This Mazda is actually my second car, my first being a 1996 Ford Telstar (which I drove into the ground), and if I remember correctly used the same 2.0l as the 626. Just drawing comparisons to the two cars since along the lines they're a bit similar, but anyway. When I got my car it was just to be my daily for school and work. I pulled what was left of the sound system from the Telstar and installed it, which sadly enough took 3 people (including myself) and entire day to connect a headunit and sub.. After maybe 8 months of having the protege is when some issues that I couldnt ignore stated pestering me. First the clutch was slipping, no suprise, the car was 11 years old at this point. Then the struts were cracked and leaking, replaced all of those. Around this point was when my mate suggested lowering my car, since he'd just lowered his the week before, and that it would help reduce some body roll. So my first mod was Lowering the Protege, and this was when i realized how much I actually love this car. From that point I started looking up other parts that would make the Protege just that bit better.
I don't have any stock high photos (sorry...) But this was straight after we lowered it
My Protege and my sisters Civic
Bought the car from a car yard, had about 19X,XXXkm's on it, and needed a good service to get it running up to standard again. Replaced the factory leads and coil packs since it was miss firing terribly.
Mod List
Engine
-Flat black rocker cover
-Hurricane 4-1 header
-2.25" custom exhaust with Magnaflow high flow cat, resonator and 4" cannon muffler
-Mishimoto radiator
-OBX Racing silicone radiator hoses
-custom intake with K&N pod filter
-Sickspeed single tone horn
Brakes, wheels and Suspension
-RDA drilled and slotted (dimpled) front rotors
-16" alloy wheels
-205/55/16R Kumoh tyres
-Pedders low springs
-Monroe struts
-Corksport front strut bar
Audio/Interior
-Kenwood headunit
-Kenwood rear 6x9 speakers
-Cadence front 6x5 speakers
-Sony Xplod 1000w 12" sub
-Kenwood 1000w amp
-SAAS volt gauge
-Drift carbon fibre gear knob
-Custom rear parcel shelf
Mod List
Engine
-Mishimoto radiator
-16" alloy wheels
-Monroe struts
Audio/Interior
-Kenwood headunit
-Kenwood 1000w amp
-SAAS volt gauge
