Pics or it didn't happen!!! As far as I know, you just have one incredible set of headlights sitting in your living room!
Soon. (shady)
Soon. (shady)
Pics or it didn't happen!!! As far as I know, you just have one incredible set of headlights sitting in your living room!![]()
I've had people ask me that question while standing two feet from the back of my car lol.
I had someone call my car a yaris at a car show...when I was parked in the middle of my club of ALL MAZDAS...
They were trying to start a conversation with you, don't you get it? A pretty girl that likes cars like you do.. is a treasure, everybody wants to get your attention one way or another. (drive2)
Andres
In for Exhaust pics!!!
UPDATE -
Finally back with some real build progress and not just teasers.
I've done a lot of thing so far to my Mazda 2 but for today I'll focus on my headlight project that i actually completed back in October 2012. All in all, from the time i got the UK headlights till the time i actually finished them took about 6 to 7 months to complete. I did this on purpose though. I took my time. I tried to think things through. I could not risk screwing this one up. It was a lot of work and the final out come was very gratifying and challenging.
Saying that... i will never attempt to do this again.
Crashed & Broken UK Projector Headlights -
I contacted a UK Mazda dealer and they were just fine with selling me a new set of projector headlights but i didn't want to spend $1800. I could have gotten some used ones from my source in Thailand for $900 ( not including shipping ) but he ran out of them.
So i hit up UK eBay! I found the right side headlight for $78 ( not including shipping ) then i had to sweat it out for another two weeks before the left side headlight showed up on UK eBay. Got it for $120 ( not including shipping ). Only issue? They both belonged to two totally separate wrecked Mazda 2's. Each in great shape except that they both had broken attachment brackets.
Broken & Fixed Brackets -
Since the original brackets were broken i had to create my own. I used metal sheets, J-B Weld and a Dremel. Used my stock brackets as templates. I then finished them off by sanding them down and spray painting them black. Not an custom show finish but it did the job and happy to say they are still intact.
Figuring it All Out -
The over all shape of the US and UK headlights are the same. The insides and the back areas are not. I took my time and figured out exactly what i wanted to do and what materials i needed. After exchanging more than 100 emails discussing my project with The Retrofit Source I ended up buying a couple of The Retrofit Source HID kits, HID harness and assorted parts.
These original US wires work and fit on the UK headlights. You just need the right wires from The Retrofit source.
The right stuff from The Retrofit Source
All the Hard Work -
I had to Dremel cut the UK shroud pieces. A lot. It was time consuming and nerve wracking. If i screwed up it would be game over. No way to buy new shrouds. Needless to say i took my time.
After a lot of trail and error I had to create my own bracket to hold the HID assembly in place. I tried using the original UK bracket but it wasn't going to work out. Just wasn't long enough for what i needed and some of the outer brackets got in the way.
I hate seeing bulbs. Looks cheap and not cool. So I decided to complicate my life further by converting the UK high beam lamp into a halogen high beam projector.
I managed to some how scratch this inner UK piece badly. I had it sanded and painted gloss black.
I wanted that BMW angle eye look so i bought these great parts from The Retrofit Source to go over the low beam HID Projector.
Like i already said. I hate seeing bulbs. So I decided to complicate my life even more by deciding to find a smoked lens online that would fit just right and look cool. Amazingly, i found a couple of Suzuki Boulevard VZR1800 Smoked Indicators Turn Signal Lenses that fit and looked perfect.
The original UK headlights have chrome shrouds. I'm not a fan of chrome so i painted the shrouds a dark grey which would fit into my white, black and grey theme.
So here is the bracket i showed earlier with the HID locked to the back of it. I used the UK headlights original long bolts you see in the background to attach my custom bracket to.
I had to extend the HID outwards toward the front of the headlight so that it would stick out from the low beam shroud. I used spacers to achieve this. Worked just fine and are solid enough. Also used strong tape and zip ties for added hold and support.
Them i installed these clear smoked angel eye shrouds with angle eyes over the HID projector. This ended up fitting nice and tight through the low beam shroud.
This is the inner shroud of the high beam.
This is how the high beam shrouds ended up.
The low beam with angel eye. Fit just right. If i hadn't of extend the HID with the spacer this would have not been possible.
This is the Suzuki Boulevard VZR1800 Smoked Indicator installed without the shroud.
Almost finished right side.
Almost finished left side.
Over time!
After the oven i held the assembly together nice and tight with some big rubber bands.
Testing the light. The pattern isn't as crisp as i would like but it's fine.
HID and angle eye wires out the back. Bought the rubber cups to cover up the holes from you guessed it... The Retrofit Source.
Wired up to the engine bay.
The End Result -
I'll let the following photos do all the talking.
Not Done Yet -
The high beams are not as of yet connected since i did not know how to do it myself. I do have the wire harness form The Retrofit Source to make it work however. Thankfully I have found an electrician to do the job and will do it soon. The low beam HIDs and angel eyes work and look great. I also want to get the angel eyes to work separately since at the moment they turn on with the low beam.
Excuse me as i don't remember all the details since i finished this project in October 2012. If you have any question go ahead and ask.
I will take some more close up photos of the final job this weekend. Including photos with the lights on.
These UK headlights are for right hand drive, did u convert it?
I've got a set from Japan that I'm slowly working on. My plan is to convert it, though I haven't figured out how, yet. I'll post details when I finally progress that far.
Picking up a pair of HID's probably would have been easier to get it all set up right. Instead I decided I wanted to run LED headlights (not as good as HID's, but better than stock). I'm using the low-beam projectors that came with the headlight and picked up a set of high-beam projectors. Those will take some work to fit well. I've already cut up most of my high-beam shroud to accommodate a second inner shroud. This is all going to take awhile, I expect.
