Mazda How-To Quick Links
So sad that some of these How tos no longer have the images :'(
yep, that the only down side to linking to images. They eventually get deleted or moved around. TO bad it doesn't auto attach the image to the post but I would imagine that would eat up storage like no other.
is there a conversion thread for making P5 fogs HID? thought there was but been searching and not finding on forum and in the list......
Somebody should make a thread on how to use the TurboXS Knock light with J&S Safeguard. Since J&S Gauge it's too big and will need a 52 mm gauge pod.
Heres your "how-to"...
https://bbde7e0b-a-62cb3a1a-s-sites...xu-I9btGbvW6ugtXjQbm6uAAPcohkR&attredirects=0
But doesn't the J&S come with a light array thats much more informitive than just a single light?
Edit, found it, looks like it also includes a wideband display?
Added
<a href="http://www.mazdas247.com/forum/showthread.php?123844119-How-To-Install-Hydra-Motorsports-gauge-rings-(Remove-Instrument-Cluster)">Protege - Install Hydra Motorsports gauge rings </a>
This just happened on Thursday (mad) anyone do a write up, or replace the rad support themselves? Would greatly appreciate pics. Have the time, just not the funds to take it in. And it looks fairly doable. Why not get to know my P5 inside and out.
@Antoine hey mate none of the links work in this thread now are we able to get them working again? 🙃
Not sure it’s possible to get them working again at this point..That said, there are a couple workarounds you could try…
Option 1. Do a site search for the thread title keywords and check the “Search titles only” checkbox…You should be able to find the thread easily (if it still exists).
Option 2. Use this simple URL format and copy/paste the thread ID at the end…
https://mazdas247.com/forum/t/
To find the thread ID, simply copy/paste the thread link (from the linked thread title) and you’ll see a series of numbers in the original thread URL. Copy/paste those numbers at the end of the URL format in your browser and load the page which should show the thread (if it still exists).
A quicker method would be to copy/paste the original thread URL into your browser and simply edit it so that the format matches… https://mazdas247.com/forum/t/ and then load the page.
For example…
Original thread URL (no longer works): http://www.mazdas247.com/forum/show...ports-gauge-rings-(Remove-Instrument-Cluster)
Edited URL (works *if thread still exists*): How To: Install Hydra Motorsports gauge rings. (Remove Instrument Cluster)
Hope that helps!
@Hammo Had an idea...Maybe AI can update all the links?
Testing the output here first...Then if looks good, I'll update the original posts...
"How-To" Quick Links
Brakes/Wheels
Protege - Wheel Bearing Replacement
Protege - Rear Caliper Removal & Pad (disc) Replacement
MP3 - Front Pad/Rotor Change (No 56K) (UPDATED)
Replace Front Caliper Dust and Piston Seals
Universal - Stainless Steel Brake Lines
Universal - bleed your brakes, clutch, etc ALONE!
Universal - Paint your rusty brake rotors
Unviseral - Paint Brake Calipers
Universal - Repair curb rash and paint rims
Engine/Exhuast
Mazda3 - PTP Kicker Mount How-to
Protege - 626 Headers on 2.0 Protege
Protege - KLZE Swap
Protege - UDP Install
Protege - FS-DE Camshaft Installation
Protege - VTCS Removal and Porting
Protege - Side inserts installation
Protege - Ebay FMIC Setup
Protege - Prodigy's How-to Rebuild Your Transmission (G15M-R)
Protege - How To Change Manual-Transmission Fluid
Protege - WGA (wastegate actuator) replacement.
Protege - Timing Belt
Protege - SMIC HOW TO: Circuit Sport SMIC
Protege - Custom Cold Air Intake
Protege - remounting overflow tank with stock brackets
Protege - Intake Manifold Installation, Removal, Thermal Spacer Instructions
Protege - CP Racing STB in a P5
Protege - Racing Beat rear Sway bar on P5/ES
Protege - Install GHL Turboback
Protege - Install a MX-6 Rear Strut Tower Bar in a Protege5
Protege - Install a MX-6 rear strut tower bar in your Protege sedan
Protege - How To: EGR Removal and Cleaning, Rough Idle Fix
Protege - Kill your turkeys
Protege - AWR Rear Mount Install -- Instructions
Protege - S-pipe removal, w/out turbo removal
Protege - Turbo Oil Lines
Protege - Install In-Tank Fuel Pump
Universal - Build your own Vacuum manifold
Universal - How to Sea Foam your Engine.
Universal - How-To Beading Intercooler Piping...
Universal - Install Kartboy Exhaust Hangers
Universal - Boost Pressure Tester
Universal - Painting Valve Cover
Universal - How to Paint Valve Cover and Exhaust Heatshield Manifold Part 1
Universal - Auto Tranny Flush
Universal - DIY filled motor mounts
Universal - Clean Your MAF Sensor
Universal - CEL/MIL Eliminator!
Universal - Change your Oil
=Install Header
install Protosport Downpipe
change valve springs
Remove/Install Tranny and LSD or disassemble gears
Progress 22mm Rear Swaybar Installation
Spark Plug Install
cure Cel/Mil from removing cat with Non-Fouler
2.0 NA Header Installation
MZ3/MS3 -OEM alarm shock sensor upgrade
Mazda6 - 2.3L Thermostat replacement
Body/Suspension
Protege - Rear Strut Bar in a Sedan
Protege - Install Racing Beat RSB / Clunk Fix
Protege - Bumper Removal for Protege5/MSP/MP3 w/ pics!!!
Protege - How To: Replace Front Sway Bar Bushings on a p5
Protege - Front Wheel Bearing Service
Protege - Fix your trunk leak!
Home Depot Lip
Custom Sway Bar End links
Restoring faded paint
How-to: Make & install your own Mud flaps / guards for less than $5
Fix a plastic bumper
How to remove Vinyl graphics
Underbody Braces
Roof rack removal
Use 93-96 Mazda MX6 rear strut tower bar for a P5
Removing Back Badges and Filling Holes (mp5)
Install DG Motorsports AutoExe Replica Grille
H&R springs(on a P5)
stop the rattle in L+R rear bumpers in P5
MSP FSB Install
P5 Bumper/03.5 Lip On ES/LX
Install Autoexe Wing and Brake LED relocation
Remove Roof Rack (P5)
How do you remove The stock MSP grill?
Shaving Side moldings
Remove your 03.5 MSP lip
M6 Wagon Wiper on P5
Stop the P5 spoiler from rattling!
JDM Style Front Upper Grill
Instuctions On How To Install Tein Springs
How To: Lowering Spring Install
MS6 - Rear subframe/suspension removal step by step
Electrical/Interior
HID Projector Headlights
Protege - Retrofit HID projectors into P5 headlights
Protege5 TSX Projector Retrofit
Protege - Projector/HID Retrofit Into Protege Headlights
Protege - AEM F/IC Install
Protege - How to Program Keyless Entry
Protege - Gauge Cluster Bezel by Maxx Mazda
Protege - TurboXS Knocklite
Protege - City Lights Mod for P5 v1
Protege - City Lights Mod for P5 v2
How to upholster your Protg/MP3/MSP
Protege - fog lights always on
Protege - how to foglight mod. *with pics*
Protege - Custom Shifter Boot
Protege - JDM OEM foot lamps installed!
Protege - Gauge Cluster Disassembly
MS6 - How-To: Gauge Pod (MINIMAL to no damage method)
KDC-MP919 Ribon cable repair info
How-To: LED interior/reverse/licence plate light
MSP - SS AFC Install How-To
MS3 - Install an external amp with BOSE HU (Pre-Amps)
MS3 - How to hard wire radar dectector
change fog light bulbs
Gauge cluster removal
Locked Out Prevention Circuit
Painting Interior Pieces
Aftermarket Seat Install (Recaro SRD)
Joe MBC Complete Install with pictures
pull Front door speaker wire...
Stock head unit with RCA outs (P5)
Swap Tachometer with Aftermarket Gauge
Greddy Profec B Spec 2 HOW TO
auto turn off head/parking lights
Gauge Disassembly
Installing Fog Lights (w/ pictures)
Haltech Max Boost Pressure Adjustment with Haltec Boost Controller
Kill Door Chime
Replacing A/C Control Panel LEDs
Gauge Dim With Cluster Dimmer
Keyless Entry Bypass
Installing different sized speakers in your car
3rd Gen Variable Intermittent Wiper Mod
Install MAM master door lock bezel
Automatic unlock doors when you pull the lever
Protege - MSP Sub/Amp Rack install on a P5
install Celica style clear bumper lenses on your P5
rewire fogs for always on
Greddy Full Auto-timer Install
Make and install your own GROUND WIRE KIT
Install an Autometer Boost Guage
1st Grounding Kit for MSP
Electric Window Mod for Always On
Install an amp wiring kit
Wire Interior Neons
Wire Fogs on a 2003.5 MSP
Water Temp gauge installation
Remove center Dash trim (Radio surround)
Air/Fuel Ratio Gauge install
One Touch Auto-opening Moonroof
Solution To Flickering Fan Speed 2 Or 3 A/c
Disabling Automatic A/C - Defrost modes
Tint your turn Signals (or Tail Lights)
headlight black out for P5
CANADIAN fogs on/ DRL off
install short shifter
Change Your Horn
replace headlight bulbs
Protege - P5 Rear Door Panel Removal
HKS type 0 Install
Protege - Essential Speed Stage 1&2 for your MSP
Protege5 Fiberglass Subwoofer box
Wow...Looks like it worked, chewed through those links like nothing, would've taken me forever to do it manually...
