40mph wicked vibration
no it's easy just take apart the transmission and reinstall everything
Apparently the ring doesn't necessarily fall but you're supposed to jam something in there to keep it from falling,...
It may be something else but I'd look into that first.
Ok..all is well for CV axles...I do have a question...if the passenger cv axle was broken would it affect the wheel bearings?
Thnx
...if the passenger cv axle was broken would it affect the wheel bearings? Thnx
I would think the heavy vibration would stress the bearings.
You're supposed to tell us what was wrong ya no,... and how ya fixed it ???
Did you loose your magic ring ???
I replaced both left & right cv axles..the passenger side was the one with cracked axle..wow..ride id different but have little bounce and road noise on that same side...gets louder as I speed up. Drive great though no vibration or shakiness.
The ring was stuck to the medal of the car not on the axle...re-installed and it was fixed.
I'm gona replace right wheel bearing and see that helps.
