Cool!'06 auto sport... 238k miles... Mostly reliable, but started to have some stalling and sputtering today. Religiously maintained.
Mazda brakes were an issue early on, and replaced an alternator, O2 sensors, plugs, and many headlights bulbs...
Cool!
Looks like you are the original owner? Have you replace anything on the ignition side (coils, plugs, starter)?
I hope that was not a typo and that you found Tokico products that work on the Mz5!! Do tell! When I last looked into Tokico, they don't offer anything for the Mz3/MS3/Mz5.Yes original owner... the ignition side has been reliable; only regular plug changes (3rd set now). Radiator cracked at 210k miles and lost the small long heater hose at around 200K miles. A couple of O2 sensors, and belts. Has been fed synthetic oil since 5k miles. The crappy OEM suspension (struts/shocks) blew fairly early... replaced with decent tokico parts at about 60k... still holding up. Goal is 300k, God willing.
That's a bit of work for an '09 with 50K! Did you choose to do the plugs and anti-freeze that early? OE replacements are expensive but they are spec’d to last longer than 50K. I do recommend doing something with the ATF asap.53k on our 09.
She's only needed basic (some not so basic) maintenance (syn oil, plugs, air filters, brake pads, anti-freeze, sway bar bushings). I've also had to replace passenger side motor mount, full suspension, sway bar end link (dealer did it), & the crap Mazda battery.
I have a vacuum leak to track down and a trans flush to do but nothing too serious yet. Glad to hear yours is holding up so well!
