I got it off DH gate but I now see it on ebay
http://www.ebay.com/itm/HD-CAR-Radi...Video_In_Dash_Units_w_GPS&hash=item3a8b086ed2
This is the one i got off DH gate
http://www.dhgate.com/product/andro...2/165295345.html#myaccount_orderdetail-1-null
looks like the exact same one, same price too, although mine came with the wifi dongle and this one says its $25 extra?
Here is a review i posted about it
2013 Mazda 5 USA model
Pros:
The radio fits great and matches the dashboard perfectly, including the red backlit knobs and buttons.
Volume knob responds quickly no lag like some other radios.
It has android 4.0
Once in ACC position radio shows Mazda logo and the AM/FM part of the radio is instantly usable (4 or 5 sec after ACC on) so no long boot times with no audio, android does take some time to fully boot but at least you can listen to AM/FM while the android system is loading.
Very easy to switch between android and the main system (push GPS button)
Audio quality is better than the stock radio.
The system was a direct "plug and play" with the factory harness (I did have to connect the illum wire but that was very easy to do and was not necessary). Another thing to note is the deck already knows when you go to reverse, I guess the factory deck had wiring for it already since its using the factory connector.
I love being able to choose which GPS to use, since its android I have the shipped iGo and also just installed Sygic.
One word NETFLIX, with a portable hotspot/tether you can watch it on the go, way too cool
Cons:
I wish the bluetooth would link to android instead of just the main software so I could run apps like torque from the radio. Also since android can't see bluetooth you can not use android to make calls, they must be done with the main system.
This only happened one time, but the display, while showing android, flickered every time the screen was touched but if you switched to the main system (used GPS or RADIO button) the screen would be ok, only way to solve it was to turn the key off and then on, but that did only did happen once.
Very quick shipping, once the radio was ready to be shipped.
The radio was packaged well and nothing was damaged in transit.
I would recommend this deck if asked, for the price what you get is worth it.
