hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
P0090 is a fuel pressure sensor code, you may have a leak on the line for that sensor or another line/gasket leak.
It's a code for the sensor, the regulator is likely fine they rarely fail on Proteges.
It's probably the only solenoid I don't have. It's leaning out at 4k, so I'm guessing it's not allowing enough vacuum to open the FPR to increase fuel pressure, thus creating a lean scenario.It's a code for the sensor, the regulator is likely fine they rarely fail on Proteges.
Mine isn't pending, it codes after one road test...I got the same stupid code pending.
Back seats and all the hardware are now taken out. Hopefully the motor will be pulled out next weekend, weather permitting.
My buddy bought a spicy a while back (from scratchnsniff) that had the solenoid bypassed and the vac line from the FPR ran directly to the manifold, I never drove the car so I don't know what the effect was but some people run it that way.It's probably the only solenoid I don't have. It's leaning out at 4k, so I'm guessing it's not allowing enough vacuum to open the FPR to increase fuel pressure, thus creating a lean scenario.
Top of the IM near the TB, brown connector.Then where is the sensor located?
I may just try that. It's a free way to see if that's the culprit I suppose.My buddy bought a spicy a while back (from scratchnsniff) that had the solenoid bypassed and the vac line from the FPR ran directly to the manifold, I never drove the car so I don't know what the effect was but some people run it that way.
Actually I just removed it and applied direct power and nothing. Then ohm'd it and it's an open circuit.I may just try that. It's a free way to see if that's the culprit I suppose.
dash next? haha
Dash has to stay in for SMF. Next will be making a bracket for my Sparco Rev seat and then either finding another passenger seat or replicating it. Wish I had a vacuum setup. I was screwing around on Forza for at least 3 hrs doing different setups with alighment and tire pressure and added a front splitter and added canards for s**** and giggles and dropped my time on a small autoX like course by over 1 second. Pretty sure I will be making one of those next and go from there. Rear wing adds stability at high speeds, but sucks for that setup since you qant the ass end to swing out faster. Really want to make a deck lid and rear diffuser to be a little more lighter and would look sweet.
I think they consider the trunk part of the unibody structure. For a local event you might be fine, but a national event someone might rat you out and they will either DQ your times or bump you to XP
