Mazda5 Wheel Fitment & Photo Guide
Yeah I've found wheel clearance against the struts to be an issue, but only in the front so far. The rear seems like it would fit a 17x9 for me if I really wanted to shove a 255/40 tire back there- but that's somewhat pointless to me from a function point of view. Would look damn sweet though. :)
Yeah, the front does seem to be a problem. Let's just say, I'm able to run a 18x10 with a 225/35 tire. I'll leave you guys guessing the offest... for now (sssh)
Ok, they're at the powdercoaters now. 14 day turn around (bang)...
Powdercoater JUST called me this afternoon and told me my wheels are ready and that they will be there most of the day. I guess that means I was supposed to run down there and get them after they've had them over two months and I've already put tires on my OEM 17s. That being said, when I do get around to picking them up, they may end up in the classifieds section. 14 days! HA!!!!
Hi!
My Mazda Premacy 20Z on the 18th wheels (235/40R18)
Looks good in white with those wheels.
interesting LED option on the headlight.
Removed mazda logo on the back gate is kinda lame :)
I like it! But yeah, put the badges back on- or fill and smooth your holes. Are the black lines stickers or actual vents?
I have a chance to buy a set of 2012 MS3 Stock Wheels (18"), with the intention of putting them on my stock 2013 Mazda5 Sport. Can you guys confirm or deny that this will work with 215/45-18 tires? I love the look of 18's, but my wife wont let me roll the fenders, and she'll kill me if they rub while she drives it.
Can't confirm from experience, but that setup should work just fine without rubbing, especially on stock springs. What suspension do you have?
Hope this works with the h&r sport springs:
18x8 with a 45 offset. 215 45 18 tires.
Just the stock suspension and a Cork rear sway bar. I asked about the non-standard tire size because that's the rubber that comes on the rims. My idea is to use them as-is, and then switch to MS3 stock tire size when they wear out.
nissan wheels on a 2012 mazda 5 ?
Hey Guys , Not sure if this is where I ask this or not, Just joined and WOW !! Alotta Knowledge Here !! Thanks For Having Me.
So I have a 2012 Mazda 5, I already got a set of H&R springs,(not installed yet ) and just picked up a set of 18x8, and 18x8 1/2 Nissan 350z wheels .
What size tire would I use ? I put between 150-200 miles a day on, doing roadside service. I want a lower stance, with some wide tires? Don't mind if it sticks out a little, and maybe a little bit bigger in rear , just for the look . But really need something that can handle all the abuse, and try to ride decent. I spend about 12 hours a day in it. Please any help from the Pro"s would be great, Cant afford to screw up on buying tires, My Wife is already flipping about the springs I bought her for Christmas :-)(wow)
Thanks Guys
here's my 09 with the speed 3 wheels ur looking to do. the fact that they fit on a previous gen 5 should mean there's a very good chance they'll fit on urs. I'm dropped on BC coils with no rub
That looks very nice !!! Gotta love that white . Nice Job
Porsche Cayenne wheels 17x7.5 et65. Adaptec adaptors 20mm front 24mm rear. 205/50/17 bridgestone Ecopia tires.
