I love love love my MS3 rear sway- it matches the 5 extremely well with the stock front bar.
Amen brother. I've got the same set up as you except with stock springs.
Yeah, I did. End up greasing it almost once a month.
Why not up the FSB to balance the RSB?Replace my Tri-Point RSB with MS3 RSB over the weekend. I definitely miss the direct steering response from the bigger Tri-Point RSB. But its much safer on wet / snowy road. It have a lot less tendency to oversteer during tail braking. Being this is my wife's car the MS3 are better and safer for this application.
I still need to stiffen the rebound on for the rear shock. I have it at 1/2 a turn and I might need to increase it to 1 full turn. This KONI yellow have to be disassembled completely to adjust rebound on the rear shock. Front strut are really easy with just turning a knob but rear have to be torn down completely.
Huh, thought it could be accessed via the rear cup holders/panel.
the top of the strut can be accessed from that spot, but the rear mazda3/mazda5 koni's are only internally adjustable and require to be dismantled for adjustment.
Why not up the FSB to balance the RSB?Also, do you have your alignment numbers?
totally understand on the family van needs. I don't think the MS3 FSB will be much stiffer since it is only +3mm (13% bigger), unlike the rear which is a +6mm (30% bigger) diff. Sway bars more affect body roll. There are other things that impact ride comfort more. Also, how did u decide to go tri-point in the first place?This is family car and stiffer is not the direction we want to take with this car. Plus the tire would never have the grip to match anyway. My alignment are stock since the camber/caster are not adjustable on this car.
