Reverse lamps - fuse or wire colour.
Berty
Eunos Cosmo
I am trying to intercept the wire for the reverse lamps on the Cosmo as close to the drivers position as possible. Does anyone know the fuse that it runs to or where I can intercept the wire?
What are you up to now Berty?
Kramer
I've installed a Dakota Digital GSS-2000 which is a gear indicator unit. Because my gearbox has a valve body which adds another gear via manual selection, I've stripped all of the factory electronics off the box.
The GSS-2000 can read what gear you are in and then display it on an alpha-numeric display. Further to this, you can tell you ECU or Boost Controller what gear you are in and vary the amount of boost accordingly.
The GSS-2000 now also controls my neutral safety switch and reverse lamps, hence needing to trace that wire. I'll update my build thread with pics once I get this figure out.
