strange issue with the A/C
Mazda3s 2007 / CX-5 GT 2014
Blower pos 1 desnt work Mazda Protege (SOLVED)
Hi!
I have a issue width my A/C. When I put the selector in 1, the AC button is on but the fan doesnt work when I put the selector 2-4 the fan works but the AC button goes off.. what do you think?
best regards,
Edwin..
Hi!
best regards,
Edwin..
sounds like 2 problems to me... as far as putting it in 1 and the light being on but no fan that sounds like a bad blower resister.. and 2-4 no ac sounds like the infamous flickering issue
:( do you think I have two problems?... this weekend I will disassemble the panel to inspect this...
Thanks
Edwin
I'm going to take mine apart edmartz, My issues started after a car accident so it sounds 100% reasonable that my connectors are loose. even if I get them working I hit a bump and they die out again.
Hi!, finally I solved the problem. The problem was related to the blower resister.. I buy a used one, installed and now the four positions works well. I found the explanation here:
http://www.justanswer.com/car/3npto-2002-mazda-protege-turn-ac-on-blower-motor-position.html
Here is the schematic:
