Hey #2, I could go pick them up for you and deliver to the menchies meet tomorrow night. LMK
Thanks for the offer! I'll definitely let you know.
Typically companies that make aftermarket wheels like what will always have a larger bore so it fits more makes/models of cars.
Ya I typically see the larger bore sizes. Since the bore on the XXR wheels is 6.1mm larger, do I absolutely have to use hub centric rings? Or can I get away with not using them? I would think that as long as you put the lugs on in the correct order (diagonals), the lugs should center the wheel right?
