dont know if is a transmission problem??
boostoli
2003.5 mazdaspeed protege
quick question guys. sometimes when I try to shift first my gear wont go it gets stuck same for second gear. what could be the cause?
Yeah I was have a hard time with 1st, 2nd, and 5th at one point. It turned up to be the bad stock plastic bushings where missing. I put in corksport bushings and tada... Problem solved. Hopefully in your case it's as simple as that
ok thanks alot ima take a look at it tomorrow
