Airbag light blinks in "code"...
monsta
Contributor
06 5 Touring, 07 Sport
Figure the airbag light is blinking a code that could be deciphered.
Does anyone know of the "code"/pattern?
eg: I will get one long blink followed by 3 short blinks sometimes. It varies and I haven't really concentrated on the code.
Seems it has to do with the passenger seat airbag defeat.
Mine just started blinking in twos. Blink blink pause. Blink blink pause. This is the red light on the dash, above and to the left of the green light that shows that the headlights are on. The passenger airbag light (to the right of the radio) is not on.
On the flashes, there may be two short flashes then a pause, then two longer flashes then a pause. Or maybe they are all the same - just as I was checking it out I was on the interstate and my TPMS went off, the good news is that it works fine, there was a one or two second beep with the light. I didn't feel any steering issues so I pulled off at the next exit which was a mile ahead and pulled onto a side road, under a street light. My driver's side rear tire was completely flat in less than a minute. Turned out that I ran over some piece of metal on the interstate, I could feel the air coming out of the tire. This metal piece was about 3/4" long, like somebody jabbed a knife in the tire and broke it off. Weird. I have "road hazard warranty" on the tire through Discount Tire, I'll get it taken care of tomorrow at minimal cost.
And just a reminder - check the pressure in your spare. Mine was at 15 psi, it is supposed to be at 60 psi. I drove at 30 mph for a couple of miles to the next gas station, it was fine but luckily there was a station that close.
Any ideas on the airbag lights?
My 06 manual doesn't show any codes for a long flash - just patterns of single flashes. I hope you figured it out
My 06 manual says the 4 possible codes for 2 flashes: B1192, B1193, B1194, B1195 - you need an OBD reader to get the code. The "system malfunction location" for the respective codes are:
1) Driver-side side air bag module circuit short to power supply
2) Driver-side side air bag module circuit short to body ground
3) Driver-side side air bag module circuit resistance high
4) Driver-side side air bag module circuit resistance low
The warning blink should repeat 5 times when first powered up.
good luck
