hazy headlight assemblies
Replacing the whole housings is like the people that buy a new computer instead of fixing/cleaning/maintaining the old one. Yes some (many?) of the computer-cleaning programs/services are scams but there are also a number of free non-scam methods that work fine but that's going off on a tangent.
just to follow up on that comment, if you still have the same computer for more than 5-6 years, chances are your computer is an outdated POS...
but yeah it looks like some of the clean-up kits do work pretty well, based of the pictures that have been posted. i just question the longevity.
What attachment do i need for my drill / die grinder to make this easier and more effective? I have the solution but dont want to do it by hand. Let me know. Thanks.
I think the 3m ones sometimes come with a drill adapter. Basically you just need a backing plate with a drill fitting. I really don't recommend a drill though, it's easy to miss the headlight a little and scuff your paint. It honestly dosent take long to do it by hand.
Since I've tried the Meguiar's and 3M kit already, I decided on a whim to pick up the Duplicolor kit since it has a spray-on UV clear coat. I'll report back after it's been applied for some time to see if it'll keep the hazing away longer than with no clear coat. My headlights are clear right now from the Scratch Out that I use.
https://www.amazon.com (commissions earned)
I went to Auto Zone and found two 3M kits, one is for use with a drill and the other is a non-drill verison. I bought the non drill version. It turned out great. I bought a can of Krylon clear coat for plastic which said it was UV protectant. I haven't had a chance to spray it down.
I saw two 3M kits at my local Advance Auto. One had a some sort of protectant in it as well. Curious as to how well it works since it didn't seem like it was a spray kind.
Do you know how the protectant was packaged (pic on the box)?
Do you know how the protectant was packaged (pic on the box)? The UV protectant in the Sylvania kit was in a packet and extremely thick. You squeezed it out onto a supplied cloth and then wiped it by hand right onto the lens.
They didn't have the one w/the protectant in-stock or else I would have looked at it.
I didn't put on the protectant since I plan on spraying clear coat.
But if you took the time to clean them up and have the protectant on hand, why not use it also? A double layer of protection!
The synthetic protectant is a paste-like substance that you would apply like wax and buff off. I want the clear coat to get sprayed directly to the plastic.
The clear coat may not stick as well if the protectant was applied first ??? (my can of clear coat says "surface must be clean and dry")
I just did our Civic's headlights today with the Sylvania kit and that description is not right for the kit they are currently selling. There are 3 containers in the box: (1) activator in a pump bottle, (2) polish (they call it something else, clarifying compound, or something like that) in a foil pack, and (3) final UV protecting coat in a small bottle. The UV protectant is a yellowish slightly viscous transparent fluid, the polish is very thick and not transparent (that is, it looks like most other polishes).
I did these headlights when I first bought the car used 3 years ago. At that time I just used various grades of sandpaper and polished at the end with some generic metal polish. That looked good for about a year and a half, kind of ugly for a year after that, and unacceptably foggy from that point on. (I rarely drive at night, so there was no hurry to fix this.) The headlights looked about the same at the end of the previous treatment as they did with the Sylvania up until just before the UV protectant was put on. So I would not say that the Sylvania was any better than just sanding and polishing for treating the plastic. However, the activator does seem to work, as most of the yellow discoloration came off the headlights with just that fluid. Honestly it looked a bit like somebody had pissed on the headlights, since on the rinse yellow drops run off the headlights. With the yellow gone, the total amount of sanding was reduced, I think I only sanded for about half as long this time. (Possibly because I sanded so long last time?)
The UV protectant, which is some sort of clear coat, did make the lights very shiny after it was applied. Unfortunately the Civic headlights are not just curved, they have raised "bumps" where some of the optics poke out a bit, and it was moderately tricky wiping the stuff on and not missing spots. I'm sure if I did this a couple of times I would get the hang of it, but doing it only once, the coat did not go on perfectly. It has some wavy areas, and there is a blotch on one headlight where I had to go back and spot on some next to one of the bumps, where the cloth jumped over a few millimeters (like a skier coming off a hill). My daughter has the P5 with her in another state at the moment, but my recollection is that its headlights don't have these bumps, so that would not be an issue.
My one recommendation for the Sylvania kit is to go very, very heavy with the UV protectant on the cloth. They say to do that in the instructions, but there is only the one little bottle, and you don't want to run out on the 2nd lamp. As it was I undershot the mark, and there was about 1/3 left after finishing the 2nd headlight, so I could have used more, and that would have helped with the skipping on the bumps. If I had it to do over again I would have poured half of the UV protectant into another little glass bottle - easier to judge how much is being used. Another tactic would be to use a sharpie and mark a half way point on the bottle.
Doh...you are correct! I got the UV protectant mixed up with the clarifying compound. I had about 1/4 left in the bottle when I finished so know what you mean about using another bottle to split it evenly across both lights.
