I certainly can appreciate it. I guess my thoughts were that because everything is different, and improved for the most part, why 95% it? But it's all good. Your project, your boat to float. As long as you're happy right?
First p5 drift?![]()
Hopefully you've looking into the Doc B Oil pump service...
external oil pump with dry sump system?
With the tranny in the back (am I right to say that?) the system could go in the engine bay, right? Then weight distribution would still be good? Or am I thinking about it all wrong? Regardless, excited to see the end result!
I have been reading over your entire thread over the past week (when im not working) and the whole talk of a RWD P5 gets me thinking. but my main question, if not already answered. how are you going to transfer the power from the motor to the rear wheels? now, i know i sound stupid asking this (i do understand how FWD and RWD cars put power to the wheels) but are you going to use a "FWD" form of putting power to the wheels... in the back? if so you might want to look at something like this, ferrari came out with a semi-wagon that is AWD. but instead of using a transfer box from the tranny before the drivetrain. the front wheels are powered by gears in the actual block of the engine. Top gear UK did a show on it. have you considered doing something like that? not AWD but the setup like that? I love the build and will keep up with it! keep zoomin! P.S. sub.
For inspiration, Fiero lovers like to take the V8 out of the FWD Caddys and swap those in. Of course there have been many Fiero V8 swaps from many different platforms
youll end up doing a wheelie if you were to gun it! haha!
Which begs the question. What are you going to do when the car handles like crap?
I forsee many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many,many, many, many, many, many, issues with this build. The car and its suspension were designed to have a motor in the front. the factory weight balance was about 60/40, so when you put that motor back there and the balance becomes 30/70, what are you gonna do? the front will have no weight to keep the tires on the ground and probably understeer worse than proteges already do. The chassis is also reinforced in the engine bay to withstand the torquing of the engine between shifts and every time we jam the gas pedal. the floor boards in the rear of the car were not meant to handle that. they were meant to handle a few hundred pounds of relatively static weight. if you think you can do this then hey more power to you, but im gonna go ahead before this all starts and say that i think its a lost cause, though i do hope to see you finish it
