I've had an idle problem with my MSP for awhile, but only on warm starts or when it's warm outside (70s and above). It fires, drops to idle, and then drops way down, stalling on occasion. I usually hold my foot on the pedal so it 'runs' around 1k rpm until the symptoms go away (about 20 seconds or so). Then it runs great until the next time around.
I've cleaned the IACV twice, hunted for vac leaks, replaced the plugs and coils with no luck. Last night I decided to take the IAC solenoid out and test the thing to double check that it was working. I set it up on the bench with a 12V source and all is good - valve pulls in when voltage is applied. I then went back to the car and checked that voltage was present across the two contacts on the voltage source connector for the IACV; it reads 12.15V when the ignition is 'on.' I plugged the IAC in (not installed) and turned the ignition to the 'on' position and the plunger didn't budge. I cleaned the contacts on both sides, made sure there was a solid connection, double checked for voltage, and the IAC still wouldn't move. I wiggled the wiring harness around with my multimeter attached to the connector to see if there were any breaks in the wiring, but it held a steady 12.15V the entire time.
All this had me second guessing what I was doing(detect), so I tested the IAC solenoid to discover that my initial thought pans out. One contact is +V, one is -V. I wasn't sure if the solenoid chassis was the ground and there were two input signals to reverse the direction or not. That led me to measuring both the connector terminals on the wiring harness relative to ground. Turns out the negative terminal has a steady 0.06V showing, keeping the solenoid from functioning.
I looked at the FS wiring diagram, and it shows the IACV being fed by brown (BR) and gray (GY) wires. Mine has brown and white. I didn't see any connectors near that location that have brown and gray wires, so it wasn't switched with something else. It shows the brown and white (gray) wires going to pins 54 and 83 respectively on the PCM. I haven't checked to PCM to make sure the same color wires on in those pins yet.
That being said, do any of you have suggestions on what to look at next?
The car has been modified, but nothing has been done to the original electrical system. Thanks in advance for the help!
