Where do you guys have your ssafc mounted??
Dvdap
Mazdaspeed Protege 2003.5
As stated I'm going to install my ssafc this week and I'm wondering where is a good place to mount the unit.
Thanks pics would be nice
I was thinking that but with it being hinged I figure it might be bad to have the wires and vacuum line move often
drill a hole in the bottom of the glove box and run the wires through the hole. I have my AEM mounted in the space in front of the cup holder, all kinds of room under there. I just have to remove the cupholder plastics and the unit is easily tuned.
I have installed a couple of these and I just run the vac line through the main wiring harness grommet and put the slit second on the ledge above the ECU. Put some velcro on the bottom and it will sit there forever.
I have mine located behind the right (passenger side) kick panel. There is a recess there where it fits nicely.
Mine sits in the glove box and the wiring runs through the opening in the top, it fits perfectly and the wires don't pinch or rub. I have seen them installed under the cupholders and I liked that idea.
