had a change of heart...... might keep the MSP & pick up DD for the time being...
still saving for a house so i really don't want a car payment until i purchase property.
How are the sickspeed horns compared to the hella supertones? I know this is an old post, but I'm trying to find out which to go with.
knock offs VS the real deal. I've heard many bad things about the knock offs dying to soon and sounding terrible. There is a reason the knock offs are so cheap.
good choice. The main thing they look at is not your downpayment, it's how much you can afford monthly and any car payment, credit card payment etc. cuts into that.
For me it was better to payoff my wife's car and have no car payment than have the extra money for a downpayment.
But why shell out the extra cash when you can get the knockoffs for way less and save some money...
why do things twice when you can do them right the first time? If you want garbage keep supporting knock off companies, me personally im willing to pay more to know i wont have to do things twice.
plus hellas aren't that much more, still well below the $100 mark. They also come with the relay and are louder than the sickspeeds
But Rotas are sooo awesome!
Haha, clearly forgot to hit the sarcasm button... What I don't understand is people agreeing that knockoff horns are lame but other parts like knockoff wheels are acceptable... And I'm not pointing the finger at anyone in particular just the general mentality...
As I sit on the side of the interstate letting my car cool off I figured it'd be a good time for an update... Cars still not idling correctly, cleaned the maf and it didn't help, checked it for cracks and it seems to be fine, I finally ha a code come up on the car last night after I got on it a little, the code was a camshaft position sensor circuit malfunction. And something else isn't right with my car, it pours water out of my overflow can almost everything I drive it, it doesn't run hot though. Well at least not until today, so I'm sitting here waiting for it to cool down and going to check my water and limp it home. I'm probably going to end up taking it to a mechanic to, I'm tired of trying to figure out what it is
There is probably a flow problem in the coolant system, are the coolant hoses both hot?
my coolant spewed out when my thermostat effed up. guess it was stuck or something
water pump or temp sensor maybe?
Bottom coolant hose isn't hot, top one is warm. Just put a new water pump on it when I swapped motors
And there she sits while I wait
^well it looks good at least. I would try temp sensor and make sure the rad cap is functioning
The cap seems to fit snug, i put a protege 5 radiate in it when I swapped motors as got a new cap, could it have something to do with the heater core possibly? I flushed it out when the motor was out and a bunch of nasty stuff came out of it, the previous owner put stop leak in my radiator and it messed everything up on the inside of my motor
I hate how auto correct don't work when I type on here! Lol but I turned my heat on when it started over heating and I had no heat what so ever, it was just blowing cold air
p5 rad doesn't cool as well as the stock msp. Did you change to a fmic or did you always have it? maybe it doesn't have enough airflow to the rad
