I got a lot done this weekend.
Mounted rotors, calipers, pads, and flex-lines on the rear subframe assembly. Adjusted the e-brake throw so it was all happy. Mounted rotors, calipers, pads, and stainless steel flex-lines to both front corners. I installed the new front struts with FM bump stops, FM springs, and complete NB upper mounts. Hooray!
Ground off and drilled out a front sway bar bracket bolt that had been snapped off and welded over. Ran a tap through the old threads and they cleaned up pretty well. Drained coolant and moved the hot-pipe and cold-pipe hoses to get the front sway out and install a new and shiny FM front sway bar, brackets, and bushings. Re-installed racing-beat adjustable endlinks to connect it all.
Front suspension is completely back together!
I also assembled the rear struts. Equivalent parts as the front struts. Waiting on a few friends to come over to man-handle the rear subframe and install everything at once.
Also TIG'd a catalytic converter into a Berk stainless b-pipe for an MR2 guy. Not my prettiest work by a long shot, the fit between the cat and the piping was not great, but it's glued together and won't fall apart right away.
Fixturing:
Fitting the cat in after cutting out some of the downpipe:
Finished part:
I also installed a dishwasher and installed trim around two doorways and the floor in the second floor hallway in my house. Crazy weekend...
