Oil Cooler / Spin On Oil Filter Conversion = $420 Seal!
Mazda 5 GT
In trying to update my 2009 Mazda 5 cartridge oil filter to the current Spin On Filter Conversion, I inadvertently split the silicone seal/gasket between the oil cooler and the oil filter housing! This caused me to lose 4qts of oil during start up and almost lose my engine! Be careful not to do what I did!
Does anyone know how to resolve this problem?
The seal is only sold with the Oil Cooler = $420!
I removed the ridged (looked like 1/2 o-ring on top of silicone gasket) silicone seal from the plastic plate attached to the oil cooler and tried to make one myself out of Make a Gasket Silicone but to no avail. Carefully beaded the caulk onto the plastic plate, let it form a skin. smoothed it out leaving enough for compression with an ice cube, put together, tighten bolt on cooler to housing, let dry 36 hours,re tightened.
Started it up = oil seeped out at seal interface! Totally frustrated!! In DYI for more than 45 years, this got the best of me!
Any thoughts:
Resources to purchase just the Plastic Plate/ Silicone seal rather than the $420 Oil Cooler with seal.
How to build a silicone seal that will withstand the oil pressure.
PS: I looked on this site and they sell this gasket, which I going to try. Note item # 14-702 @ oil cooler assembly: http://www.jimellismazdaparts.com/showAssembly.aspx?ukey_assembly=299330
Just looked at the diagram for the Mexico Oil Cooler, A lot cheaper than the USA model quote!
Pics of the offending install , Do not know how to add to topic! Any help?
Many Thanks to all Forum members, Brad
Man, that's a bitter pill to swallow! I've not read of anyone else having this aggravation and I barely looked at the oil cooler connection when I did my spin-on conversion. Good luck! Does Jim Ellis Mazda want $420 for the Mexican part?
My mistake, the $420 price was for a Federal/California/Canada model... called Jim Ellis, Mark at the parts dept said they can get the "Mexico" Model for $132. The only difference is in/output lines in this unit are straight. Don't know if this will work. Mark also stated alot of his customers have a problem of tearing/breaking the oil seal on the oil cooler, forgot to ask him what they did. May get the Mexico cooler if available locally,if not a remote cooler may be better...cooler oil temperatures.
Any thoughts anybody?
Is the conversion different for some cars? All I did with mine was unbolt it from the filter platform and bolt it back on. I've had to do this twice, since I broke the first one, peeling the filter off against a parking curb. :(
just buy the seal for $5 to $15 dollars and do it yourself.
you can order the oil cooler seal on ebay for $15, or just call your local mazda dealer and get it ordered for about $5 (plus $2.50 for overnight shipping if needed)
i just had to do it the other day for mine as apparently i tore the oil cooler gasket sometime during the removal/reinstallation of my spin on conversion too
part number is LF8X-14-702
the gasket is just slightly different from the original one on my 2007 ms3 (that one has little tits to hold it in the retaining ring) as where i had to line this one up and have a second person tighten the oil cooler assembly to the spin on housing from the top side of the engine bay (a 24" 3/8 drive extension helped)
but its been in place on the car for 2 weeks, ~300 miles, with no issues or oil loss after putting everything back together
Spin On Oil Filter Conversion = $420 Seal .... NOT!!!
UPDATE: Just have to buy this gasket: LF8X-14-702 same as pictured. $4.70 list, exact replacement w/o any headaches... woohoo!
UPDATE #2:The gray ridge part of the o-ring on the black plastic spacer/gasket interface between the oil filter housing and oil cooler had torn when it stuck to the old cartridge housing,causing the leak between the new housing and the oil cooler.
Original Post:
Any thoughts:
PS: I looked on this site and they sell this gasket, which I going to try. Note item # 14-702 @ oil cooler assembly: 1400A - OIL PUMP & FILTER (2500CC). Fits: Mazda | Jim Ellis Mazda
Just looked at the diagram for the Mexico Oil Cooler,which I bought, not knowing if the Plastic Plate/ Silicone seal was available for purchase. A lot cheaper than the USA model quote!
PS Thanks to Silentnoise713 for his knowledge base
Thanks for the follow up on the part number and your solution to the problem.(detect)
Hopefully this serves as a warning to the DIY oil changers to keep an eye on this part.
I still have no idea what part this is. I'd keep an eye on it if I knew.
This is not a part a DIY oil change will ever encounter. You will only run into this part if you are converting your cartridge filter base to a spin-on canister filter base (or messing with things). Even then, I still don’t understand how the OP manager to destroy it. It must have been an accident, which happens but definably not something that ‘breaks’ easily.
This gasket exists between the oil filter base/housing and oil cooler attachment resting on top. ’09 (some say later ’08s too but I haven’t heard of any) and up cars came with canister type filter so you wouldn’t touch this unless you want to go back to cartridge filters, in which case I’d be happy to sell you a cartridge base/housing -cheap :D
http://www.mazdas247.com/forum/show...anister-filter-–-Mazda5&p=5911877#post5911877
@ OP - you should correct the title of this thread so as not to scare newbies. $420 is not quite $4.70 ;)
