With the bc coilovers can i fully adjust camber? Or will i need to buy something else?
You can get around -3 degrees in the front with the camber plates... in the rear the strut mounts are slotted and you can get about -2 degrees. Adding camber bolts to the top strut mount will get you to -3.6
