Any luck for a good aftermarket mud guards for our 5?
Crystal White 2012 Mazda 5 GT with Luxury Package
I know we have a oem rear for the 2012 5's but none for the front.
I saw on a thread here that it didn't make much of a difference either where the dirt still gets sprayed on the body side.
I was wondering if you guys found a solution with aftermarket mud guards that does the job well?
Thanks!
I haven't purchased them, but I've been eyeing the urethane sets produced by Corksport and RallyArmor for the Mazda3/Speed3. I talked with Corksport about their set and they said the front should fit just fine, but they're uncertain about the rear. Nobody tests these things on the Mazda5 so it'll be up to us to figure it out.
Here's the RallyArmor set: http://www.rallyarmor.com/store/1013-mazda3speed3-urethane-mud-flaps-c-60_130_133.html
Here's the Corksport set: http://www.corksport.com/corksport-mazda-mud-flap-set.html
They seem pretty much equivalent, but the Corksport is a little cheaper.
My GS came with front mud guards, I inquired they want $110 for the rears! I'll go without for now.
Thanks for the link.
I'll probably just wait for an oem to come out since I'm not savvy enough to mess around with this things.
I see that there are both front and rear OEM splash guards available for the 2012 Mazda 5. I have been considering these as well. Does anyone have experience with these OEM products?
I bought the OEM front and rear mud guards when I purchased my 5. The fronts were very easy to install, just popped out a couple of push buttons and install, didn't even have to take the wheels off. The rears I had to take the rear wheels off because you have to drill one hole on each side in a fender liner. Other than that installation was straight forward.
