Complete Protege Turbo Setup
Status
Not open for further replies.
if you can pm me with details on the suspension set up and the battery tie down, that would be awesome!
i can send you stock shocks if need be... ready to look like a road racer rather than a rally car lol
The suspension is spoken for. I will pm you once I make the thread for the tie down
Thanks!
Its still available!
Sorry I havent been on in the last couple of weeks, in the process of moving so things are a little hectic
Im really not trying to break the kit apart at this time.
I dont have the corksport J pipe, just the S
How easy would you say this is to install? Is it completely bolt-on or do I need to make any modifications to my car?
Install is not going to be difficult. because I would be sending you EVERYTHING you would possibly need to install it. Coolant lines, oil lines, fittings, return lines, vac lines, tapped oil pan, etc...
The ONLY moddification comes from the Perrin front mount. The cold and hot pipes go through the radiator support, its not hard to cut since its not part of the frame.
Status
